Install shower arm
Discussion in 'Shower & Bathtub Forum & Blog' started by markdiy, Sep 28, 2004.
  1. markdiy
    markdiy New Member
    Sep 20, 2004
    What is the best way to install a shower arm? The area is already drywalled with a hole for the arm to attach to the fitting. Can I use a pipe wrench or do I need a strap wrench or something like that? How tight does it need to be? Any other tips on making the connection leak-free are appreciated.
  2. jadnashua
    Most shower arms have a bend in them. Assuming that it isn't a really cheap arm (flimsy), that angle should give you enough leverage to tighten it up without tools. You will need either pipe dope and/or teflon tape to seal the threads to prevent leaks at the fitting, though. One or the other should suffice, but I see a lot of plumbers using both - can't hurt. A shower arm doesn't have a bunch of water pressure in it unless it has an on-off valve in it.
    More tape is not better. Two turns is enough. You want it snug (from just screwing it in), then probably another 1/2 turn (using the force available from the angle). More is okay if you need to get the angle aligned. Check it, and give it more if needed. You don't want it moving around if you adjust the showerhead.
  4. jimbo
    jimbo Plumber
    The shower arm is almost too "slippery" for a strap wrench. You can use a very large screwdriver for leverage, but be careful of the threaded end. A cheap arm can go out of round.
    This is one of those jobs where you get a "feel" for it after you have done some. The trick is to recognize during one revolution that it is "enough" and stop when is comes into line. If you go past the "right" spot, you may not be able to get al the way around.
  5. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Plier's Handle
    I use the handle of my pliers by sticking it up into the arm for added leverage.
Similar Threads: Install shower
Shower & Bathtub Forum & Blog Delta rain can shower head install Today at 7:12 AM
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Steam Shower Generator Installation Nov 22, 2016
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
