Install bathtub over tile?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Xenomorph, Jul 30, 2006.
  1. Xenomorph
    Xenomorph New Member
    Jul 10, 2006
    Anyone know if it's ok to install a bathtub over a ceramic tile floor...by this I mean extend the tile underneath the bathtub skirt...or will this just cause the tiles to break when someone steps into the tub and the skirt bears down on the tile?
    thx
  2. jadnashua
    If the tile is properly installed, it should not matter.
  4. hj
    tub
    it is easier for the tiler and it eliminates the gap between the tile and tub which is always a potential leak source when the grout cracks or pulls away from the tub. Unless the tub is very poorly installed no damage to the tile will occur.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    It is O.K. If the tile goes all the way under the tub to the wall or the tub is set in mud to level it with the tile floor if the floor does not go all the way to the wall.
    If the tub is set on the floor and the tile only goes a few inches under the skirt the tub will not be level.
  6. Xenomorph
    Jul 10, 2006
    thx for info guys
  7. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    We tiled up to an existing tub in one bathroom, used a sanded grout-color-matched caulk in the seam next to the tub. Provides some flexibility, so theoretically it won't crack and leak. In the all-new master bath we tiled right up to the walls everywhere.
  8. hj
    If the tub is set on the floor and the tile only goes a few inches under the skirt the tub will not be level.[/quote]
    Most tubs have to be leveled anyway, regardless of what the floor looks like.
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    What's under the tile?
    The supporting subfloor is more important than the tile -- if it flexes too much, you might have grout (and tile) cracking with the weight of the water-filled tub.
Similar Threads: Install bathtub
Plumbing Forum, Professional & DIY Advice Bathtub Installation - Leveling Oct 17, 2015
Plumbing Forum, Professional & DIY Advice Bathtub install help Aug 17, 2015
Plumbing Forum, Professional & DIY Advice Bathtub drain installation... Jun 22, 2015
Plumbing Forum, Professional & DIY Advice CONFUSED! - Bathtub Overflow Installation - Does anyone know what this is? Dec 2, 2011
Plumbing Forum, Professional & DIY Advice Basement bathtub drain + roughin install gone wrong ? Dec 5, 2010
