Inspector says: “The toilet-vent must be upstream of the toilet.â€
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lahabra, Feb 7, 2008.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I can’t figure out what he wants me to change.
    I plumbed in a toilet flange with no san-tee. I used a 2†wet-vent through the sink drain. I think I did my plumbing correct. I think I just need to explain the plumbing concept to him.
    What should I tell him?
  2. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    is a wet vent allowed in your area?
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    looks ok for our area
    the toilet looks to be vented in to the
    2 incl line going up off the 2x3 why which
    should be some sort of wet vent......
    unless that line is serviceing the washing machine
    that should be considered a wet vent.. for the toilet
    it dont have to be upstream here
  5. hj
    vent
    The vent connection has to be downstream from the fixture's trap, which your's seems to be if we are seeing it properly.
  6. whats up
    whats up New Member
    Dec 4, 2007
    is there a 45 dgr fitting goeing up rite after the vent ?if so the trap arm is higher than your vent.
  7. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    No,
    The trap arm only drops 1/4" per foot
  8. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    No flat venting allowed. It gets blocked with sewerage [You don't know it] and
    You end up with No vent. See if He will allow a low heel 90 and vent up into the wall behind the toilet.
    [​IMG]
  9. Garrett
    Garrett In the Trades
    Feb 5, 2008
    Georgia
    exactly, you need to roll the wye up at a 45 degree angle so the vent will be above center grade.
  10. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    That is what I have.
  11. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I did not create any flat vent.
    By the way, I read that flat vents can be used for toilets if done properly.
  12. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Toilet's vented, but where's your end of line clean out?
  13. Terry
    Aug 17, 2004
    Like SR Denny mentioned, you have rolled the combo at a 45, for the lav that is wet venting the toilet.
    If you had an end of the line cleanout, that would be all he could ask for.
    That could be done by rolling a 3" combo, a 3" 45, then a 3" cleanout tee, with a fitting reducer on the top for the lav above and vent above.
    But not vented? As long as the inspector allows wet vents, that's what it is.
  14. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I could extend the drain and add another vent up stream of the toilet.
    sewer...................v...............WC...............v
  15. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Went into the city to meet with the inspector. As soon as he saw me, He said: "the plumbing was already approved" and he had intended to stop by to sign the card. I did not ask any further questions.
    Problem solved.
  16. Terry
    Aug 17, 2004
    Yeah baby, that's what I'm talking about.
    Now that makes sense.
  17. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    yeah! alot of good learning
  18. hj
    vent
    What you have is perfectly okay, and that is why he approved it. As for "See if He will allow a low heel 90 and vent up into the wall behind the toilet", most inspectors will reject that because material WILL splash into the 2" opening and could clog it.
    [​IMG]
Similar Threads: Inspector says
Plumbing Forum, Professional & DIY Advice Inspector says: “The toilet is to close to the wall†Feb 5, 2008
Plumbing Forum, Professional & DIY Advice Before I get slammed by the inspector... May 26, 2015
Plumbing Forum, Professional & DIY Advice Inspector wants an RPZ for residential home Feb 20, 2012
Plumbing Forum, Professional & DIY Advice Replacing a leaking Instant Hot tank, Property Inspector LLC, Woodinville Jan 28, 2011
Plumbing Forum, Professional & DIY Advice Coming to a Plumbing Inspector near you Dec 7, 2009
