Inside of toilet PVC pipe has cut marks - an issue?
Discussion in 'Toilet Forum discussions' started by arnav, Aug 23, 2013.
  1. arnav
    arnav Member
    Aug 23, 2013
    Florida
    In the process of taking out a 4" all plastic PVC toilet flange for the first time I left a few cut marks on the inside of the pipe from the saw I used to cut the "quarters." I should have cut less. Taking it out with a chisel was not a problem so there was really not a reason to cut more vs. less. Oh well, I will know better for the next toilet... The cuts are about 2" to 3" down and maybe 1/32" deep.
    Anyhow, is this an issue if I prime and glue a new inside flange?
    Should I just use an outside 4" flange to remove any doubt? I have enough space around the pipe.
  2. Terry
    Aug 17, 2004
    The outlet of the toilet is 2" dropping into a 4" pipe.
    It won't make a bit of difference. Glue up!
  4. arnav
    arnav Member
    Aug 23, 2013
    Florida
    **** sigh of relief ***
    Thanks a million...
    I got paranoid from all the DIY videos that showed how to take the flange out which really emphasized not touching the pipe. Probably still a good idea / best practice but like you say don't compromise anything if the pipes has some cut marks on it.
    Thanks again.
Similar Threads: Inside toilet
Toilet Forum discussions Dripping Sound from Inside of Wall/Ceiling When Toilet is Flushed Jan 15, 2017
Toilet Forum discussions Is it normal to hear leaking from inside the toilet? Mar 24, 2012
Toilet Forum discussions Has anyone tried using Stone Sealer (Aqua Mix, etc) inside a toilet? Jul 17, 2011
Toilet Forum discussions Inside diameter of Toilet flange too big! May 15, 2011
Toilet Forum discussions inside fit 3" toilet flange and wax ring Apr 14, 2008
