inside fit 3" toilet flange and wax ring
Discussion in 'Toilet Forum discussions' started by schak, Apr 14, 2008.
  1. schak
    schak New Member
    Apr 14, 2008
    I have a toilet flange that was roughed-in my concrete floor basement when my house was built. Now years later I’ve finished my basement and ready to install the toilet. Breaking the flange knock-out revealed that the flange was fitted inside a 3†ABS pipe, not outside. My problem now is the standard wax ring horn? will not fit inside the flange hole, it is too big.
    Do they make a wax ring for flanges that fits inside a 3†pipe? Do you have any other suggestions of how I can make the toilet bowl work with the current toilet flange. I read somewhere that a 3†inside fit flange should work fine for a 1.6 gal/flush toilet, which is what I have.
    TIA
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Dry fit the toilet over the bolts without a wax ring to make sure the toilet will fit it. Not all do!
    Then if it does use a wax ring without the black plastic funnel. They cause more problems than they ever fixed and this problem you noticed is one of them.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The do make flanges that will fit inside a 3" pipe, but they are not recommended. They cut the inside diameter of the drain too much. Also, get rid of the wax ring with the plastic horn. They cause problems and do absolutely no good. Just use a regular wax ring.
Similar Threads: inside toilet
Toilet Forum discussions Dripping Sound from Inside of Wall/Ceiling When Toilet is Flushed Jan 15, 2017
Toilet Forum discussions Inside of toilet PVC pipe has cut marks - an issue? Aug 23, 2013
Toilet Forum discussions Is it normal to hear leaking from inside the toilet? Mar 24, 2012
Toilet Forum discussions Has anyone tried using Stone Sealer (Aqua Mix, etc) inside a toilet? Jul 17, 2011
Toilet Forum discussions Inside diameter of Toilet flange too big! May 15, 2011
