Inserting toilet into pipe with rubber sleeve
Sprinkler
Barcelona, Spain
I want to insert a new toilet into a pvc pipe by using a rubber sleeve but I think it might be a tight fit. Is there any household type lubricant, cream (or even soapy water?) I could use with the rubber sleeve to make it easier to fit? Thanks
Jimbo
San Diego, CA
Please explain or post a pic of just what part of a toilet you want to insert into a rubber sleeve. !!!!!!!!!!!!!!!!!
Sprinkler
Barcelona, Spain
It's a horizontal wall pvc outlet pipe and I just want to insert the toilet bowl into it, but first to insert a rubber sleeve (accordion type) around the toilet outlet.
WV Hillbilly
WV
I've never done what you're doing but I usually use dishwashing liquid ( such as dawn ) for lubricating rubber during assembly .
Gary Swart
Yakima, WA
Without more information, all anyone can do is try to guess what the heck you are trying to do. It really sounds like you are trying to hack this installation rather than using the proper parts. I would suggest that since you don't appear to have any experience or knowledge about this installation, you should hire a professional plumber to do this job so that you know it is done correctly.
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
If you are installing a wall hung water closet, I would call a plumber and have them do it. I seen to many wall hung units break off the anchor system and shatter from improper installations. To many people assume the wall supports the water closet, it does not. The carrier bolts do all the holding and supporting. The back up nuts and washers need to be properly set, the carrier nipple needs to be set properly as well.
