Inserting a sanitary tee into existing stack that will not move
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by denikar, Apr 28, 2013.
  1. denikar
    denikar New Member
    Feb 8, 2013
    Canton, MI
    I'm investigating how to insert a sanitary tee into an existing vertical 3" stack that will not budge at all (vertically). One of the discussions I found here suggested cementing the lower part of the santee and using a fernco fitting for the top part. Is this the recommended method or are there better alternate methods?
    Thanks,
    Tim
  2. Terry
    Aug 17, 2004
    Normally it takes two of these
    [​IMG]
    Notice the stainless steel wrap that prevents the pipe from shifting?
  4. denikar
    denikar New Member
    Feb 8, 2013
    Canton, MI
    Thanks Terry
  5. hj
    If it does not move, there is no way you could "cement the bottom and use a transition coupling on the top", because you would have to cut out enough pipe to angle the Y in, then slide it down, and then whatever you are using would be too short to fill the gap.
  6. denikar
    denikar New Member
    Feb 8, 2013
    Canton, MI
    To clarify, the cut stack can be moved enough in the x-y direction, just not up and down (z direction).
Similar Threads: Inserting sanitary
Plumbing Forum, Professional & DIY Advice inserting 3" PVC in old 3.5" cast iron as a liner!! May 30, 2014
Plumbing Forum, Professional & DIY Advice Inserting toilet into pipe with rubber sleeve Jan 1, 2009
Plumbing Forum, Professional & DIY Advice Inserting a Tee into an existing copper line Jul 17, 2007
Plumbing Forum, Professional & DIY Advice Inserting a fitting into the middle of a drainpipe? Feb 12, 2007
Plumbing Forum, Professional & DIY Advice Inserting a Qest tee Mar 21, 2006
