inserting 3" PVC in old 3.5" cast iron as a liner!!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by switchex, May 30, 2014.
  1. switchex
    switchex New Member
    Aug 11, 2006
    Maryland
    I have to replace old and cracked cast iron that goes from the basement into the street about 6 feet before reaching the city sewer line. I am calling a couple companies to get estimates for either a liner or a total replacement. Once they give me a line to the inside of the house, i can do the rest of the job.
    However, I have been thinking of a way of doing the job myself!!! assuming the old line is straight with a 3.5" diameter, would it be possible to clean it out and insert a 3" PVC in it? I can use a camera to see how far I should insert the PVC in and stop few inches before reaching city line.
    Did a lot of research have not seen anyone doing this .. whether it is a good or totally stupid idea, i am surprised no one has tried it!! what do you think?
    Do I have any other do it yourself/cheap options?
    Thanks.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
  4. hj
    The plastic pipe WOULD NOT slide inside the cast iron. but if it did your plastic would have to be undersized. IF the cast iron is really 3 1/2" that would be the O.D. which is the same as 3" plastic ".No one has tried it, because they realize it would be a "dumb idea" for many reasons.
  5. dj2
    dj2 Active Member
    Aug 13, 2013
    California
    1. First you need a camera check to see the inside of your main drain line.
    2. Another option to pipe replacement is relining. However, you need to find out if it's feasible in your case. If not, you're looking at replacement. Prepare money.
Similar Threads: inserting cast
Plumbing Forum, Professional & DIY Advice Inserting a sanitary tee into existing stack that will not move Apr 28, 2013
Plumbing Forum, Professional & DIY Advice Inserting toilet into pipe with rubber sleeve Jan 1, 2009
Plumbing Forum, Professional & DIY Advice Inserting a Tee into an existing copper line Jul 17, 2007
Plumbing Forum, Professional & DIY Advice Inserting a fitting into the middle of a drainpipe? Feb 12, 2007
Plumbing Forum, Professional & DIY Advice Inserting a Qest tee Mar 21, 2006
