Input on well water setup needed
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Cobble Hill, Oct 28, 2010.
  1. Cobble Hill
    Cobble Hill New Member
    Oct 28, 2010
    Cobble Hill BC Canada
    Hello. Background: I have had my iron filter refurbished due to clogging. I was not given the option of a new unit, which would have been cheaper. I was not told by the service tech that the filter and softener I have require appx 200 gallons each to flush. I have an old small (22gal)wellx tank . I have no well log. I'm guessing at 1 GPM or less.
    So, my solution so far. I have purchased a 500 gal poly holding tank. I want to run the wellwater to this tank, then onto a 115v 1hp grundfos jetpump, into a 33 gallon wellrite tank.
    My questions are about both the electrical and supply lines.
    The deep well is 240v. I was going to use a float switch combined with a flip flop switch to operate the well. This is to keep the well from overwork and reduce the chance of pumping sludge. I was going to run the jetpump from the original pressure switch on a new 110v circuit
    I was going to use the well's 1" poly to feed the big tank, and then switch to 1 1/2" pvc reduced to 1" to feed the jet pump,well tank, and onto the filters. I'll be on 3/4" pex after that....
    What I'd like to know is...am I making any glaring errors here?
    Thanks for your help.
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    If you have a limited well supply of water this sounds like a solution however I would include a Cycle Sensor http://www.cyclestopvalves.com/products.html#cyclesensor to keep your pump from running dry.
    In addition I would recommend installing a Pside-Kick http://www.cyclestopvalves.com/pdf/psidekick-brochure.pdf instead of the 33 gallon tank. The Pside-Kick will give you constant pressure with a variable flow (when demanded) while preventing the pump from cycling. It will extend the live of your water system.
Similar Threads: Input water
Pumps and Tanks Well Forum & Blog. Water is life. newbie question about floating device at water line input May 8, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Saved on the Well Drilling, Getting hammered on pump install,,,Need some input. Mar 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. New pump design, I am not selling anything. I need your input please. Apr 13, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Well and pump input Sep 14, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Help-Need Input, Suggestions on Well Tank/Press Switch setup Mar 5, 2009
