Info on gas vs electric costs?
Discussion in 'Water Heater Forum, Tanks' started by garyl53, Feb 25, 2009.
  1. garyl53
    garyl53 Engineer
    Dec 7, 2006
    Engineer
    Colorado
    Hi,
    Where can I find some info and maybe a calculator to determine the relative annual costs to run a water heater. I have gas, normal venting but the next one has to be either power venting gas or maybe electric. I am trying to determine if a power venting gas will recoup the higher purchase price as compared to electric.
    Thanks,
    Gary
  2. jadnashua
    1028 BTU = one cubic foot of natural gas.
    1 BTU = 0.2930711 watt/hour
    you need to know your energy costs. Gas is usually per 100 cubic feet or a therm, which is close to that (don't know the conversion).
    An electric is close to 100% efficient; a gas-fired system will lose some heat up the flue - anywhere from 50-90+ % efficient, depending on the design.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A power vent gas is more efficient that one that needs a flue, but they do cost more money.
  5. CarlH
    CarlH New Member
    Feb 4, 2007
    Northern VA
  6. hj
    heater
    Unless you are in a heavily subsidized area, such as the TVA, electric is seldom cheaper than gas.
  7. jimbo
    jimbo Plumber
    Your local gas and electric utility companies can give you operating cost estimates for all types of appliances.
  8. chris8796
    chris8796 New Member
    Jan 8, 2005
    Illinois
    You also need to look at your utility bills to determine your true costs. For example, while my electric rates are 10c/kwh in the summer, but they drop to 4.7 c/kwh in the winter (after 800 kwh). Gas bills can be equally confusing, some have a relatively low per therm fee, but have a high fixed customer charge. While others charge a high per therm fee with a low fixed fee, which can affect the numbers if you use gas for other things. Unfortunately, there are no easy comparisons. If your looking at the energy star numbers on the yellow tags they are based on 64 gallons day (average household 2.2 people), the average family of 4 is closer to 100 gals a day.
Similar Threads: Info electric
Water Heater Forum, Tanks Very Old Water Heater Info. Philadelphia Electrical & Mfg. Co. Feb 14, 2014
Water Heater Forum, Tanks Electric vs. Propane Wednesday at 10:01 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks 50 gal electric help me please Jan 26, 2017
