Indirect Water Heaters - what's the most reliable brand? And how much for install?
Discussion in 'Water Heater Forum, Tanks' started by bronxer, Aug 12, 2010.
  1. bronxer
    bronxer DIY Junior Member
    Apr 28, 2010
    Ultrasound tech
    Bronx, NY
    After tons of research, I finally decided on either Weil McLean or Triangle Tube. I'll be removing my old standard water heater and connecting up the indirect water heater to a Weil McLean CGA 7 gas boiler.
    My questions are: 1. Any info on these 2 brands - good or bad? 2. How much should a job like this cost - not including the cost of the water heater.
    I was quoted 2 prices so far- $1000 and $3000. Thats a big difference.
    I greatly appreciate any info you could supply me. Thanks in advance.
  2. jadnashua
    I've got a SuperStor Ultra. SS guts, long warranty. Any indirect should last a long time IF you don't have leaks in the heating path and don't need to add water frequently. Fresh water means oxygen, and that can lead to corrosion. The potable tank is treated for that condition, but the heating side usually isn't.
    The things to look at are the temp loss over time (a measure of the quality of the insulation), and first hour heating capacity. An indirect normally doesn't need to be as large as a conventional heater since it usually has a better recovery rate (the boiler is usually larger than a standalone tank heater), and it is better insulated. Also, often the tank is run at say 140-degrees with a tempering valve on the outlet, which makes it look like a larger tank.
  4. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    Well ACV/Triangle Tube makes all tanks for Weil McLain so, very little difference in product besides color or cabinet on some upscale W/M models.
    Does that help?
  5. bronxer
    Apr 28, 2010
    Ultrasound tech
    Bronx, NY
    Well, that explains why the two products look almost identical. My other question is regarding the cost of installation. Approximately how much should I expect it to cost to replace my old hot water heater with a Weil-Mclean? I know the parts involved aren't that much, but being quoted $3000 from Yost and Campbell just for the install really threw me for a loop. No, I would never pay that kind of money to install an Indirect Water heater. It would take almost 20 years to make up the cost of the install. That defeats the purpose of using an indirect water heater.
    So how much did any of you pay for your indirect water heater installation?
  6. zl700
    Aug 26, 2009
    Western NY
    No way to guess cost.
    To many options size, extra valve versus pump, priority or not, 3/4, 1 or 1-1/4 piping (which has an effect on recovery and CA-AFUE efficiency.
    Go with the one that sounds informed
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Local labor cost vary so widely that few plumber will even venture a guess sight unseen on any plumbing job.
  8. jadnashua
    Lots of variables. Some mentioned. Is it set up as a priority zone? Does it need its own pump? Are you required (or want) to include a tempering valve and the required extra piping to make it work? how far is it from the boiler? How far do you need to run lines to hook it into the existing water? The more connections, parts can add up and labor makes it add up faster. How easy is it to wrestle the thing into place (empty, they aren't that heavy, but are bulky and nobody wants a dented one!).
  9. Alex Rock
    Alex Rock New Member
    Oct 20, 2010
    UK
  10. hj
    HOW it connects to the boiler and its controls, will determine the cost and that is something we cannot even guess at without being there and seeing what you have now. BUT, you have to ensure that your boiler has the capacity for the heater. It is NOT "free heat", just because the boiler is already there.
  11. Alex Rock
    Oct 20, 2010
    UK
    I'm agree. It's hard to guess the cost. It depend's of a pipe, a pump and other private things. The cost varies from $1000 to $3000 becuase of a character of installation. Professional labor can esimate this job when he will see all problems.
  12. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Get enough bids so you can see a cluster in the dollar amounts when you plot them along a line [a dot plot]. The cluster center is the true cost of doing your job in your ZIPcode, today.
    If you want, you can correct the bids for credibility. A bidder that is twice as credible as the others gets his bid price cut in half.
    The median household income for your area
    http://www.zipskinny.com/index.php?zip=10467
    is low, so you'll pay less than the US average.
  13. enb54
    enb54 Researcher
    Jul 15, 2010
    Researcher
    Edmonton, AB
    Well, in 2004 I replaced an Amana indirect with a standard Amtrol 40 U.S. gallon unit, and it was about $1200 at the time. No extra piping was required though, so that was probably low for what you are doing...
Similar Threads: Indirect Water
Water Heater Forum, Tanks What else could it be: indirect hot water heater leaking? Aug 17, 2016
Water Heater Forum, Tanks High Efficiency Water Heater vs Boiler with Indirect Feb 11, 2016
Water Heater Forum, Tanks Electric Water Heater as Indirect? Sep 26, 2015
Water Heater Forum, Tanks AST Storage Tank vs Indirect Water Heater vs Electric Water heater Jul 6, 2015
Water Heater Forum, Tanks Add Indirect Water Heater? May 13, 2015
