indirect water heater question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by greatwhite, Jan 19, 2009.
  1. greatwhite
    greatwhite New Member
    Jan 19, 2009
    hello. i have superstor 30 gal indirect and it is(was) great....when there was only 3 people in house. i need more hot water now that there are 5.
    can i add another 30 gal elec plumbed in reverse storage configuration with circ pump connected to aquastat of elec tank and indirect tank as "heat source". i could boost temp of indirect to help recovery time and then temper down to 120 w/ valve?
    does anyone think this will work? i already have small bronze circ pump (think 005) and small elec tank is less than $200. much less $$$ than second indirect and a 007 and less time/work than cutting into p/s system i have (i knew i should have left another set of closely spaced tee's.......)
    any help / advice will be greatly appreciated.
    p/s i could also then have tank's electric element connected once i get cash to have backup if boiler every goes.
    thanks
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Yes you can and yes it will. Set the loop up to pump from the superstor into the electric tank/
  4. greatwhite
    Jan 19, 2009
    thanks for reply
    thank you for your reply. should i increase indirect's temp and if so what temp do you recommend ( with tempering valve, of course)
Similar Threads: indirect water
Plumbing Forum, Professional & DIY Advice SureStor Indirect fired hot water heater 120 gallons Oct 25, 2016
Plumbing Forum, Professional & DIY Advice Zone valve or its own circulator for an indirect water heater? Jan 20, 2011
Plumbing Forum, Professional & DIY Advice Indirect Water Heater Not Calling for Heat Feb 22, 2009
Plumbing Forum, Professional & DIY Advice Indirect Fired Water Heater Troubleshooting Help Nov 2, 2008
Plumbing Forum, Professional & DIY Advice indirect water heater Dec 26, 2007
