In the ball park?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by PHONEMAN, Feb 14, 2012.
  1. PHONEMAN
    PHONEMAN New Member
    Feb 14, 2012
    LAND O LAKES , FL
    Im really new at this , so Ive got a 85 gallon tank , its a regular tank no bag inside of it, just a straight
    85 gallon, Pro Sourse tank, 1 hp jet pump. Setting are 30/60 . I get 18 gallons of water before
    pump turns back on, Takes about a minute or so to shut off after it comes on. Im I in the ball park as far as
    amount of water before pump comes back on?
    Ive got a deal that goes into the side of the tank, about 15 or so inches above bottom of tank
    not sure if it lets air in or lets air out or maybe both, it has a copper line that goes to the
    suction side before it gets to the pump.
    Charles
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    With the perfect amount of air in the tank and a 30/60 pressure switch setting, you should be getting about 35 gallons draw down from that size tank. That little copper tube is part of your air maker system. And depending on how much air charge it keeps in the tank, determines how many gallons you get out before the pump starts. 18 is really not too bad.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    "Example 5
    This shows how the drawdown changes if we widened the differential between the cut-in and cut-out pressures from 30/50 to 30/60.
    Drawdown = (28 + 14.7) / (30 + 14.7) – (28 + 14.7) / (60 + 14.7) x 85
    Drawdown = 38.4 x 85 = 32.6 gallons."
    Sorry missed it by a little. But I used this... http://cyclestopvalves.com/runtime_app.php
Similar Threads: ball park
Pumps and Tanks Well Forum & Blog. Water is life. Anyone know ballpark cost to fix/replace well supply piping? Feb 8, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Check Valve or Ball Valve to HOLD PRIME Jul 15, 2012
Pumps and Tanks Well Forum & Blog. Water is life. new well in Tomball TX Sep 19, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Park quick disconnect fittings Apr 28, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Control Box Sparks Jul 8, 2009
