In-Line Vent vs. Air Admittance Valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dzd9fy, Jul 8, 2010.
  1. dzd9fy
    dzd9fy Member
    Dec 3, 2006
    Michigan
    What is the differnece between these two, and what is the recommended use for an S trap in a basement lav? I am looking at the Oatey 3901 In-Line and the Oatey 39016 AAV if that helps..... Thanks!!
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    If you have a S trap there is no point in venting it anyway.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    The 3901 is just an air admittance valve, el cheaop version. Make sure if you put on ANY aav that it is installed vertically.
  5. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    Where would you put a vent on an S trap that would make any difference. If you vent the lateral that it dumps into it still has no effect on the S trap siphoning. If you put it at the only place that would prevent siphioning, which would be the crown of the trap, then you have an illegal crown vent.
  6. hj
    They are essentially the same, regardless of what they call them. You CANNOT vent a true "S" trap. You can only use an AAV to keep a "P" trap from becoming an "S" trap.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    S straps are illegal under every code, the reason being, they are not vented.
  8. dzd9fy
    dzd9fy Member
    Dec 3, 2006
    Michigan
    Ok, thanks for the clarification on the differences between the two.
    I am a bit confused on the comments that since it is an S trap it cannot be used, so looking for some insight here. Given the trap is where it is, has worked well for the past 10 years we have been here and guessing since the house was built [1950], what is the suggestion since this is burried under the cement?
    Also, how and why would one use this valve vertically on a P trap? That makes absolutely no sense to me....
  9. jimbo
    jimbo Plumber
    San Diego, CA
    S traps used to be used, but are very prone to the trap siphoning dry, so are not allowed today. To install the aav, you could possilby santee off the vertical, turn up with an elbow, and put the aac there. Being below the flood rim, this could be problematic. Maybe a wye and a 45 to take if vertical? I would be interested in an inspectors take on this,
  10. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    The only way to do it and be compliant would be to come vertical out of the floor into a sanitary tee with the aav on top of the tee and a P trap into the fixture. As long as the S trap remains there is no code compliant way to vent it.
  11. dzd9fy
    dzd9fy Member
    Dec 3, 2006
    Michigan
    ok..... so should I just leave well enough alone? It has been working fine, I was just thinking this would be something that would be a good improvement to a less than ideal, and now not permitted use.
    Thanks guys!
  12. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    Yep, let it be. If you notice any odor, run a bit of water in the sink. called priming the trap in the old days.
Similar Threads: In-Line Vent
Plumbing Forum, Professional & DIY Advice P-trap in-line with vent Mar 28, 2010
Plumbing Forum, Professional & DIY Advice In-Line Vent Jan 16, 2007
Plumbing Forum, Professional & DIY Advice In-Line Water Filter for Ice Maker Jun 28, 2015
Plumbing Forum, Professional & DIY Advice In-Line Lint & Pet-Hair Trap Apr 3, 2009
Plumbing Forum, Professional & DIY Advice In-line screen filters Dec 2, 2008
