Impossible clog! Kitchen Sink, Wash Machine, Dishwasher!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sleiber, Dec 27, 2009.
  1. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    When we run the water in the sink, it takes a minute to go down. When we run the dishwasher, we occassionally see debris in the bottom near the drain, and when we use the wash machine it gurgles and spits out quite a bit of water before the drain lets the water run through. It has been impossible trying to loosen this clog. We've tried everything short of snaking it. We've run a blow bag down the drains and used just about every kind of chemical from liquid plumber to a drain cleaner that was so strong we had to put petroleum jelly around the drain opening so that it wouldn't do any damage to the stainless steel sink! A couple of people have told me that I should go to the cleanout under the house and run a snake up it. Does anyone have ANY other suggestions?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    That you have a seriously clogged drain is to state the obvious. By your description, it would appear the clog is major and fairly deep into the drain system. What is needed is a plumber with a "real" snake that is not only long enough but with a large enough cutting end to clear the clog. This is not a DIY project. The industrial sized auger requires skill to operate and in the hands of a novice can be literally deadly. Most of the pros advise avoiding the companies with "Rooter" in their name.
  4. hj
    drain
    It appears you have tried everything EXCEPT what you really need and that is a plumber with the proper snake to clear the drain. What you have tried so far, could have made the situation worse.
  5. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    My dad actually works for the plumbing department at a local county school district. I'm sure he can get what we need and help with the job. I was afraid that we would need an auger for this...
  6. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    He was the one who brought in the blow bag. We tried that and it seemed to help temporarily, but started backing up again pretty quick. I think it may have just been pushed farther in. What might we have done to make the situation worse, hj?
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Both HJ and I have answered that question already. You seem bound to avoid calling a professional with professional equipment, but that is what you will eventually have to do.
  8. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    Nobody answered my question of what I did that could have made it worse..
    I do have to wonder why you're still trying so hard to get me to call in a local company when my dad has 10+ years plumbing experience in the job he is in now (mentioned above). :confused: He has already said we would probably have to use a snake. We are in a mobile home so, would it really be so difficult to go under the house with a 25-50 ft snake and pull it out of a cleanout? I just didn't want to go through all of that hassle if I didn't have to. Why are you so set on me spending rediculous sums of money to a local plumbing company when I have a plumber in the family?
  9. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Wow...
    How did this turn into a 'woe is me' sob story?
  10. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    :confused: How is it a 'woe is me' sob story? I'm only asking for advice on how to fix it myself without having to snake it. I never asked anyone to feel sorry for me. I only asked for advice. Is this not a DIY forum?
  11. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    PLEASE lock this thread!
    Anyway, I got my response. It will have to be snaked. It's not like plumbing in a mobile home is rocket science, anyway. I no longer care about the question of how I might have made this worse, since I'm not getting much cooperation aside from "Call a professional plumber" (which I did... I called my dad), and the one that got under my skin a little: "How did this turn into a 'woe is me' sob story?" Please lock this thread before there are anymore asinine comments added like that last one. I'm through here.
  12. hj
    worse
    The chemicals, if strong enough could have damaged the piping. The blow bag could have "pressed" the stoppage to make it denser. For starters.
  13. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    Thank you hj. I was hoping for a response from you since I wasn't seeming to get answers from anyone else, otherwise I would've given up this thread completely and went on my way. I was afraid of the chemicals damaging the piping when I picked them up, but of course they always claim to be safe to use on whatever piping you have. I never thought about the blow bag making the problem worse, though...
  14. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Blow bags improperly applied can often make messes...
    Sounds like its snake time!
  15. hj
    chemicals
    IF the chemicals could damage your stainless steel sink, which is very durable, they could definitely damage common metals, and some plastics. With plastic, some chemicals create heat in the pipe and that could soften the plastic lines.
  16. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    For some reason people seem to be afraid of the sewer snake. A snake is the first tool that should be used.
    Drain cleaning chemicals are a waste of time and money, not to mention that they can be dangerous.
  17. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    I've heard that you can use salt brine down your drains monthly for maintenance. I tried to google salt brine and only came up with recipes for brining poultry. What is salt brine? Are there any other things you can do for maintenance other than chemicals? I've only used them in the past for lack of knowing what else I might be able to use. I know bleach helps with some very minor clogs.
    That's what I was thinking when I read that on the back of the package, but I was desperate :(
  18. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    Yep, cleaning a drain is one of few jobs where duct tape isn't useful.
  19. sleiber
    sleiber New Member
    Dec 27, 2009
    Georgia
    L.O.L. :eek::eek:
  20. Terry
    Aug 17, 2004
    I sometimes use Bio-Clean for drains to keep the pipes clean.
    [​IMG]
    But first, it's a good idea to snake the lines, and then maintain with Bio-Clean.
    I'm not a fan of chemicals.
  21. hj
    brine
    Salt water may be good to "preserve" whatever is in the drain, and vinegar with baking soda makes a good volcano, but neither does ANYTHING to clear a drain.
Similar Threads: Impossible clog
Plumbing Forum, Professional & DIY Advice Impossible to find Shower Cartridge?? Help please! Mar 11, 2016
Plumbing Forum, Professional & DIY Advice Shutting off the water??? An impossible task??? Emergency! Apr 19, 2009
Plumbing Forum, Professional & DIY Advice unscrewing metal dwv pipe (is it impossible?) Jan 21, 2007
Plumbing Forum, Professional & DIY Advice Inline water filter for coffee maker clogged, leaking carbon out inlet Sunday at 2:04 PM
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
