Imploding water heater?
Discussion in 'Water Heater Forum, Tanks' started by Dilbert, Sep 27, 2008.
  1. Terry
    Aug 17, 2004
    Got time to watch a video on exploding water heaters?
    If it were my home, and my family, I would disconnect the water heater and get it out of my home.
    Just a little North of Kirkland. I like to use Rheem and Bradford White water heaters.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Anyone get the feeling that all this is going in one ear and out the other¿
  3. jimbo
    jimbo Plumber
    I thought the tops of water heaters were made concave....in other words dished in looking from the top. So it must have take some serious force to FURTHER dish it in to move the nipples like that. I have seen pictures of tanks which were over-pressured, and the nipples tilt outward.
    I completely agree that the integrity of the top of that tank is seriously compromised, and should be taken out of service immediately.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yup!
    It's just passing through without even being processed!
    [​IMG]
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Umm, as I said in the first post, I'm not a plumber, just a guy with a lot of tools who is a little too fearless.
    What is a T&P valve? I guess just asking that question means I'm in trouble.
    Yet another shining example of the reasons why plumbing and gas fitting require experiance and a license
  6. Cass
    Cass Plumber
    Nov 12, 2005
    I have one of these tanks in my garage and will take pics of it as I strip away the sheet metal and expose the tank so we can see exactly what happened...
  7. hj
    heater
    The glass lining cannot stretch so when the steel tank "bulged" the glass lining was ruined.
  8. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Water heater pressure bulge
    Repeat the glass ling is the least of your problems ! ! !
    Poisoning your family with carbon monoxide is the most important thing that should be on your mind right now,
    your bottom head of the tank has reversed onto the burner
    look at the top of the vent where it go's out the top see that
    the flue has dropped down into the top of jacket,
    the only reason this is not more noticeable is because of the ridgid copper pipe other wise his nipples would point at each other like a tepee
    i will look on water heater mfg's websites to see if i can copy and paste a picture of what i am try to tell you ! !
  9. kingsotall
    Aug 17, 2008
    lol @ pic!
    I see now why nhmaster made this quote:
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I'm going to use this thread as a reference for future use in regards to showing how something simple as a homeowner replacing water lines can lead to impending disaster in such a short period of time.
    Just because Bob Vila does it doesn't mean you can.
    "Oh but I can't afford a plumber"
    "Oh, we're on a budget"
    "Well we just bought a bass boat, sorry, I'll do it myself"
    "Well, I'll have to get back to you after I talk to my wife"
    "If I supply the material, how much will it cost?"
  11. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  12. Redwood
    Dec 15, 2007
    Service Plumber
  13. Ladiesman271
    Ladiesman271 Homeowner
    Aug 22, 2008
    Care and maintenance of transformers
    It would not collapse if you use a vacuum relief valve on the cover. That water heater has one installed on it, but is it any good?
    I wonder how old that heater is anyhow? Even to my DIYers eyes that water heater is now toast!
  14. Redwood
    Dec 15, 2007
    Service Plumber
    It really is a moot point whether it was vacuum or, pressure...
    The water heater is scrap!
  15. tankman 2
    tankman 2 New Member
    Sep 29, 2008
    For what it is worth, the expansion tank pictured looks to be one designed for a hydronic system. Not sure if it is connected to the water heater or not. If it is a hudronic tank it will not last long on a potable water system like this one.
    btw
    I agree. Change the water heater and have a professional do it!
  16. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The expansion tank in the picture is connected to the boiler, not the water heater.
  17. hj
    heater
    Definitely. The glass liner is not flexible so any movement of the metal would crack it. But since even a new heater might not have a perfect glass lining, that is why heaters have anode rods. One thing not mentioned in all the posting, unless I missed it while scanning them, is that it is almost impossible to create a destructive negative presssure with the heater in the basement, and even if it were possible, you have a vacuum relief valve to prevent it.
  18. jimbo
    jimbo Plumber
    This doesn't end the debate, but is interesting. It shows that the bottom of a water heater is concave ( dished inward ) but the top is convex ( domed upward ):
    http://uk.youtube.com/watch?v=1ofSyXUW0TY
  19. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I wasn't aware an expansion tank was needed on a WH?
    My last house had gas WH & it didn't have one. But that doesn't really mean anything as I found a lot of problems with my old house. I have seen them on boilers, but never one on a WH connection. New house was an oil fired WH & was replaced with an electric model when the oil fired started leaking & the bottom let loose. I know a new pressure relief valve was installed, as the old one was leaking
    I saw the exploding Wh video on another site maybe 2 months ago
    I was unaware that something like that could happen
Similar Threads: Imploding water
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Saturday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Feb 20, 2017
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
