I'm sure this is an S-Trap
Gene.m
Illinois
I'm having some things redone and this looks like a 3/4 S-Trap to me. I think if the wye was moved more right there should be atleast 4" of pipe between the 45 wye and the p trap. It is a 2 inch pipe for washing machine drain.
Thanks for your help
Well, it is an S trap. I did not totally follow what you were suggesting for a cure, but it did not mention a vent.
The normal cure would be to put the trap, santee, and vent above the floor. The piping under the floor would be modified to run downhill.
Cacher_Chick
Test, Don't Guess!
The way that is plumbed, it will siphon the trap, and sewer gas will come back up into the house.
A washer trap is required to trapped above the floor, and the trap must be properly vented. A professional IL licensed plumber would know that, as would any decent plumbing/building inspector.
