Identify Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by yellbird, Apr 20, 2013.
  1. yellbird
    yellbird New Member
    Apr 28, 2010
    Monee
    I was hoping someone could identify this faucet that is on a Whirlpool Jet Tub. As you can see it is damaged and would like to replace if I can. Also how does it come off as it has no screws and have no way to access it from underneath. It is 10" high and 3 1/2 " wide at the base.
    Thanks for any help.
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    You need to get under the tub to remove the spout. And, you will need to know the manufacturer in order to have a chance of finding a replacement. If you post a picture of one of the stems next to a ruler and tell how many splines there are on the broach where the handle goes on, somebody here may recognize it.
  4. yellbird
    yellbird New Member
    Apr 28, 2010
    Monee
    Thanks for your quick reply, it is not necessary to replace it with the exact same one, more concerned about getting it off. There is a wall between it and the closet so I guess I will have a cut a hole in the wall?
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Actually, you may have to replace it with the exact same one because they are not all the same. Besides being held to the tub, there are also connections to the hot and cold to consider. You may have options, but don't assume you do. I would post a picture of the stem before you start breaking holes.
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    I opene my mouth before I thought it through completely. Check the spout for a set screw, probably low on the back. If you find one, you can loosen it and pull the spout.
  7. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  8. yellbird
    yellbird New Member
    Apr 28, 2010
    Monee
    That is the correct one and after looking at the price I will look for something else to replace it, What do you think the odds are that I can just unscrew it without cutting the wall next to it and get a wrench on the bottom bolt?/
    Thanks to everyone who commented.
  9. hj
    Once you make an opening into the area under the tub, you should be able to unfasten the spout and cut the pipe to it. Once that is done, there are many spouts that can replace it. The hole in the tub, and the connection to the spout are usually "generic" so you just have to make a connection to it. Your real problem is that there are no spouts like that, in polished brass or gold, which are "reasonably' priced.
Similar Threads: Identify Faucet
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Today at 6:36 PM
Shower & Bathtub Forum & Blog Can anyone help identify this Shower Faucet? Oct 21, 2016
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
Shower & Bathtub Forum & Blog Mixet, Cannot Identify Old Shower Faucet Jul 27, 2016
Shower & Bathtub Forum & Blog Need help identifying 1980s Roman tub faucet Oct 18, 2015
