Identify and find replacement challenge!
Daf
Texas
Hey all, we need help identifying our fixture. Through this very awesome site you guys have I think I have identified it as a Delta 1600 (perhaps 1608?) series. Here are the supporting URLs I found:
https://terrylove.com/forums/index.php?threads/delta-600-leak-question.26837/
https://terrylove.com/forums/index....dentifying-tub-faucet-delta-scaldguard.29661/
Q1 Specifically what make/model do you think it is?
While we do have a very minor leak, more significantly the handle is missing and both universal handles I've used have utterly failed. This lead me to using vicegrips, which I fear have damaged or at least rusted the metal piece (which I've labeled A and I think is called the 'cartridge'). I certainly need a handle, I probably need the part labelled A, which means removing the collar B will likely break and need to be replaced too. I suspect that these parts come as kits and are very proprietary to the make/model, meaning there are no universal or standardized replacements. This leads to my second question.
Q2 Replacement of which of these parts mandates that others will also need to be replaced too?
I am very happy to upgrade to newer version of these parts if that's possible, though if i'm required to replace the portion that connects to the copper piping itself (I think this is called the 'valve') then I'll have to break some tiles, which for the sake of my marriage I really need to avoid doing. I believe sourcing new parts is easy, but these circa 1980s will be really tricky.
Q3 Where can I buy the replacement parts I need?
Thanks for reading this long post and any help you can offer.
1. Unless you know what you are doing, call a VERY experienced plumber. Otherwise, you will wind up "twisting the front of the valve off", which means you either replace the valve or call that very experienced plumber to put it back together.
2. If you cut the retainer nut off, then you need a new one, plus the cartridge and rubber seats and springs.
3. The handle is extremely easy to replace since there is only ONE model for this valve.
Daf
Texas
Thanks hj!
I'll very happily start with the handle. Are you able to identify the make model such that I can find a handle to buy? I found lots of similar looking ones online, but they rarely if ever show an image of the rear side which obviously needs the right sized hole.
E.g.
http://www.ebay.com/itm/Brass-Craft...042805?hash=item51e3ca63b5:g:YOIAAOSw5ZBWO5v~
https://www.amazon.com/Faucet-RP239...ie=UTF8&qid=1473725976&sr=8-1&keywords=RP2391
https://www.homedepot.ca/en/home/p.delta-handle---tub-and-shower--rp2391.1000515561.html
JohnnyRock
New York
help please ? what do i have here? and where to find replacement stems, seats etc. the diverter stem has snapped. Thanks!
