Identification and operation of this setup
Discussion in 'Water Softener Forum, Questions and Answers' started by harivney, May 8, 2013.
  1. harivney
    harivney New Member
    May 8, 2013
    Florida
    I'm a dummy homeowner and would appreciate some help identifying the setup in the picture at http://img585.imageshack.us/img585/9899/p1010016fr.jpg and answer some questions about future repair or replacement.
    I believe that the tanks are 9x48 with autotrol 155s. Water source is a well in Florida. They are around 20 years old and still seem to work without any maint except I put a new timer and some valve plungers on one.
    I think the tank next to salt container is for iron and based on what I have read probably has green sand in it because I add potassium permanganate (not as often as I should) to the small round tank between the two units.
    A service tech told me I need new resin but the water is not hard to me. I will get it tested as I sensed the tech was a ripoff artist (more to this story)
    - 2 people live in house. How often should iron unit regenerate? Should it run before or after salt regen?
    - Does the resin slowly degrade and ultimately just not soften the water at all. Or is it something that either works or doesn't work?
    - Does green said wear out?
    - Do the tanks last forever?
    - Assuming that at some point in time, I will have problems with the autotrols and 20+ years on the resin and greensand, would it make more sense to buy a new setup or just repair and re-bed as needed ?
    - Are all bypass valves standard dimensions - meaning will existing plumbing attach to bypass valves regardless of mfg (autrol, fleck, etc)
    - Is there a one-tank solution for both iron and softening or are two tanks necessary with iron in well water?
    thanks in advance for any help.
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    These units are on the endangered species list. Parts are becoming harder and harder to find.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Mialynette said it perfectly.
    Wow, those are some well used systems.
    You are correct, Autotrol 155's, very durable and long lasting valves. Greensand (common 20 years ago) and traditional salt softener.
    Replace, they have served their duty well. It is time to update.
    To determine if the system can be replaced by a single tank design and perform as well, we would need an updated water report.
    Please make your electrical to code, that is not a safe installation.
    Do not attempt to use the bypasses, they almost always fail when used. That bypass was a terrible design.
    Be aware that when replacing the Autotrol valves, most valves inlet/outlet are reversed to the Autotrol.
  5. harivney
    harivney New Member
    May 8, 2013
    Florida
    Mialynette and Dittohead,
    Thank you for your clear and concise answers. After I get water test results, I'll revisit the question if a single tank solution will work.
  6. harivney
    harivney New Member
    May 8, 2013
    Florida
    Here are the raw well water specs. 2 adult household. What system would you recommend. I'm leaning towards 2- 9X48 5600 flex (one resin, one green sand) because the potperm feeder was rebuilt (new float and felt looking thing) and the potperm solution has met our needs with autorol 155.
    Raw water:
    Ph - 7.4
    TDS - 200
    hardness - 85.5
    Iron - 1.0
    Iron - bacteria - not tested
    Manganese - nd (not detected)
    Copper - nd
    Nitrates - nd
    sulfides - pos )positive
    Tannins - nd
    Is the 5600 Flex solution good enough or are there better options? Thanks for your help.
Similar Threads: Identification operation
Water Softener Forum, Questions and Answers Old Iron Filter and Softener Identification / Other ?s Sep 28, 2016
Water Softener Forum, Questions and Answers Water Softener Control Unit Settings for Daily Operation Jun 3, 2015
Water Softener Forum, Questions and Answers Kinetico Model 60 Toothed Disk Operation Sep 12, 2014
Water Softener Forum, Questions and Answers SEQUENCE OF OPERATION for KINETICO MODEL 60? Sep 10, 2014
