coldsolderjoint
I have been using my sun-room for a storage area/workshop/disaster space since we moved into the house, its now in the project queue. I wanted to put up some pictures here and get some ideas on finishing it before we get that close to doing it. It is about 10x12, and has only jalousy storm windows on it. Currently not heated nor insulated. It has a concrete slab, and a cinderblock foundation up to about waist level and then is wood framed. I'm thinking about turning it into a laundry area and storage. I want to remove the 4 windows on the long side and use that space for wall mounted cabinets for storage and a workbench area. I will do all the work myself.
Here are some of the major concerns I have now.
I want to insulate and heat it. Insulating the ceiling should be pretty easy. I can remove the thin paneling on the ceiling and insulate from below more easily than from above I believe.
Walls.. I was thinking to "fur" them out and put fiberglass batts in the window areas, I'm not sure how I would insulate the lower part where the cinder block is.
Floor.. Should I insulate the slab with something like foam and install plywood on top of it?
Heating.. I was initially thinking electric baseboards, they can be set to a much lower temperature than the house pretty much to just prevent freezing of the pipes, however, on the other side of the wall, I do have hot water baseboards which I could tap into. It is a single loop however.
I'm sure I will have about 1000 more questions on ideas, but I figured I would take some raw.. cluttered pictures to ask you guys for some ideas to throw at me.
Thanks in advance.
Thanks in advance.
