Ideal Water Pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jacksmith7, Sep 13, 2004.
  1. jacksmith7
    jacksmith7 Member
    Sep 13, 2004
    I've heard that home water pressure should be 50 - 75 psi. What is ideal? Thanks.
    Jack
  2. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    Ideal is one of those subjective words. I would say 50-60 psi is a good range. If pressure is too high, it is hard on faucets and valves. Most code requires a pressure reducer if pressure is over 80 psi and a booster is pressure is below 15psi. I am on a well and use a 40-60 pressure switch.
    Deb
    The Pipewench
  4. Kelly
    Kelly Builder/Remodeler
    Sep 1, 2004
    Builder/Remodeler
    Boerne, Texas
    All my customers are on private wells and I set all the pressure switches at 40/60. Seems to make them all happy.
    My opinion; worth price charged.
  5. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    I also live somewhere where everyone is on private well. I always let my customers know, however, that a 40/60 puts a bigger workload on the pump than a 30/50. They usually go with the 40/60.
    Deb
    The Pipewench
  6. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    80 to 100 lbs.
    We're 80 to 100 pounds although working in houses with wells they seem to do fine. Don't really miss the difference if you haven't had it. We get a lot of complaints about lack of pressure when people get a low flow faucet.
    Some kill their dandelions by blowing them out of the ground with a garden hose.
Similar Threads: Ideal Water
Plumbing Forum, Professional & DIY Advice Redoing Hot Water Radiators - Whats Ideal? Oct 25, 2006
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Yesterday at 6:03 AM
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Saturday at 10:38 AM
Plumbing Forum, Professional & DIY Advice Hot Water Recirc. w/ dedicated return Thursday at 10:27 AM
Plumbing Forum, Professional & DIY Advice Oil burner hot water coil Feb 15, 2017
