I'd like to use flexible hose to connect my trap primers...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by speede541, Mar 24, 2011.
  1. speede541
    speede541 Member
    May 1, 2010
    Oakland
    I'd like to use a short (~9") piece of flexible hose to connect the bottom of my trap primers to the copper pipe that feeds the traps.
    This would make it easy for me to disconnect the primers for cleaning and servicing.
    Should I just use PEX with the appropriate connections? I'd prefer something more flexible / supple, but in a 1/2" diameter. Suggestions?
  2. Terry
    Aug 17, 2004
    You can use a union, that makes it removable. And PEX would give you move movement then disconnecting a solid pipe.
  4. speede541
    speede541 Member
    May 1, 2010
    Oakland
    How do you like a copper union vs. a disconnectable Shark Bite connector?
    Edit: ...or what about 1/2" PEX just loosely "plugged in" the an open end of a 3/4" or 1" bell? After all, I've got air gaps elsewhere in these lines, so it's not as if they're water tight. In fact, couldn't that eliminate the need for a MI-GAP air gap threaded on to the bottom side of my MIFAB primer?
Similar Threads: flexible hose
Plumbing Forum, Professional & DIY Advice Flexible hose for connecting jet pumps... Mar 6, 2015
Plumbing Forum, Professional & DIY Advice Dishwasher Drainage Pipe To Flexible Hose Sep 11, 2009
Plumbing Forum, Professional & DIY Advice Flexible hose to rough in valve in tub Apr 19, 2008
Plumbing Forum, Professional & DIY Advice Water heater - natural gas - black iron rebuild with flexible CSST Feb 16, 2016
Plumbing Forum, Professional & DIY Advice Plastic or flexible dishwasher supply line Aug 13, 2015
