I want to install an under-the-sink water filter --- in my basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pickngrin, Sep 27, 2008.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    For the past 6 months, I've been using a Whirlpool under the sink water filter, with good results. However, today was time to change the cartridge, and getting in the sink cabinet and loosening the unit was torturous. I'd like to install the unit in the basement, directly below the sink, where it will be easier to change the filters. My question is, what is the most sensible way to do this? It would seem convoluted to run the vinyl tubing down to the basement from the sink cabinet, then back up. What would be the best way for me to tap into the cold water line before it reaches the sink valve? I saw plastic quick disconnects at Lowes today. Is it safe to make a cut in the copper pipe, use quick disconnects to attach a length of vinyl tubing, then to the filter unit, then back to another quick disconnect on the outlet side of the copper pipe?
    Thanks
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Water filter install kit
    LOOK THIS UP THIS IS WHAT YOU WANT TO USE,
    OR E-MAIL ME
    Advanced Search
    Residential
    Quick Connect Water Line Installation Kit
    Everything you need for trouble-free water line installation - all in one kit
    No soldering...No piercing...and can be installed in minutes!
    The Dormont Quick Connect Water Line Installation Kit is a unique in-line water installation kit that can be used for a wide range of applications including ice makers, refrigerators, humidifiers, under cabinet water filters and evaporative coolers.
    The Quick-Connect Water Line Installation Kit features:
    1/2" x 1/2" push-to-connect valve elimates soldering
    Integral shut off valve allows removal of appliance without leaks
    25' PEX supply line resists kinking and bursting
    1/4" quick-connect union for appliance connection
    1/4" compression fitting and ferrule also included
    Tested and certified by NSF/ANSI 61, section 9
    See spec sheet for complete product information.
    Quick Connect Water Line Installation Kit Instruction Guide
    Careers / Investors / Site Terms of Use
    Copyright © 2005-2008 Dormont Manufacturing Company.
    A Division of Watts Water Technologies, Inc. All Rights Reserved
    HomeAbout UsGuiding PrinciplesQualityCareersMapContact Us>NewsInvoice T&CSupplier T&CArchivesResidentialResidential HomeGas ConnectorsOther ConnectorsGas Ball ValvesAccessoriesPackaged ProductsResource CenterWater Line Installation KitTankless Service ValvesConnection KitsFoodserviceFoodservice HomeSafety Through MobilityGas ProductsWater ProductsPowerForceNew ProductsResource CenterOEM/Design SolutionsOEM/Design Solutions HomeFlex Tube BenefitsFlared ProductsCompression ProductsMetric Flex TubePart NumberingResource CenterCustomer ServiceCustomer Service HomeBecome a DistributorLogin
  4. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Low*s has the whole has water filters for about $50.00. Filters about $16.00 for pack of 2.
    I use these to the whole house. Why just the kitchen sink?
  5. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Thanks for the responses.
    Re: Quick Connect Water Line Installation Kit -- I wonder if I can buy that locally in-store.
    Re: whole house filter -- I bought this unit about 6 months ago and would prefer not to buy a whole new unit. The reason I didn't go for the whole house filter at the time was that I didn't feel a need to filter water for showers, washing machine, etc, and my thinking was that I would be using up filters more rapidly for non-consumable uses.
  6. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Would it be reasonable for me to install a whole house filter but only on the cold water line running to my kitchen sink (as opposed to on the water main)?
  7. jadnashua
    First off, what kind of filter are you using?
    A lot of the water you use may not need to be filtered, so why waste the capacity of the assembly? I installed a filter only faucet at my sink. Depends on what you have not how easy that would be.
  8. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    I previously had a Whirlpool under-the-sink carbon filter, but it is just too cumbersome and messy to change it under the sink. I am not finding a feasible way to mount that same filter directly below in the basement so am wondering about the whole house type unit. My kitchen faucet won't accomodate one of those screw-on-faucet canister filters. Basically, I'm looking to eliminate the chlorine taste and smell from my kitchen tap.
  9. Gary Slusser
    Retired
    First, you should not be using vinyl tubing, use PE, vinyl will kink closed.
    Buy enough tubing to allow removal of the unit from under the sink out on the floor in front of the sink where you can put the housing in a bucket. IOWs, simply don't hang the unit on the cabinet wall, it will stand up on its own, just don't knock it over, and then pull it out from the cabinet into a bucket when you want to change the cartridge.
  10. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Thanks for the idea! Actually, it wasn't vinyl tubing but I didn't know what this stuff was called. I'm going to follow your suggestion.
Similar Threads: install under-the-sink
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Wednesday at 10:36 PM
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
