I want to add a new toilet line to my septic
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Wayne67vert, Aug 24, 2008.
  1. Wayne67vert
    Wayne67vert In the Trades
    Aug 24, 2008
    Tile setter
    Sanford, FL
    tank. The new line is coming from a 90 degree angle from the inlet pipe. Is it okay to just drill the side of the septic tank and insert the new line? The tank is currently used only by the kitchen.
    Thanks for any and all replies.
    Wayne
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Maybe... Maybe not... It depends on the configuration of the inlet baffle in the tank.
  4. Wayne67vert
    Aug 24, 2008
    Tile setter
    Sanford, FL
    I understand the baffles, so if I drill into the side closest
    to the end where the inlet pipe attaches am I going to create any unforseen problems?
    Thanks,
    Wayne
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Does the baffle extend the width of the tank? Not all do!
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Ralph's a nice touch. Who's got Ron Paul?
  7. Wayne67vert
    Aug 24, 2008
    Tile setter
    Sanford, FL
    The tank is 40+ years old and made of concrete. So do I just open the access lid to check for how wide the baffle is?
    Thanks,
    Wayne
  8. Redwood
    Dec 15, 2007
    Service Plumber
    You would need to open the end where the inlet baffle is. Any line cut into the tank would have to be on the right side of the baffle. If it is a small drawer type baffle the inlet would have to wye into the line.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    I thought he dropped out of the running...
    [​IMG]
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Hey, you guys, stick
    to the subject at hand. :eek:
  11. hj
    tank
    The baffle is usually a cast in place "tube". You normally have to connect to the existing pipe before it enters the tank.
Similar Threads: toilet line
Plumbing Forum, Professional & DIY Advice Hissing sound from toilet inlet line Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Silly question regarding toilet water supply line -- what size? Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Water supply line to short for new toilet Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Vent for toilet waste line? Oct 15, 2016
Plumbing Forum, Professional & DIY Advice Moving Toilet, Adding Shower To Toilet Drain Line - Please Check Diagram Nov 28, 2015
