I screwed up, tiled my floor too tight for the closet flange to sit flush
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by annagibs, Dec 11, 2013.
  1. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
    Hi all I'm having problem that I hope you guys can solve
    I didn't account for the bevel underside of the flange so now it sticks up, rather than being flush.
    What are my options?? Flange without bevel? Somehow chip the tile away? What's best? Thanks in advance
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    1. Sticks up how far?
    2. Is it sturdy and stable/
  4. Terry
    Aug 17, 2004
    As long as the toilet sets over the flange, you will be okay.
    There is quite a bit of space under a bowl.
    [​IMG]
  5. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
  6. Terry
    Aug 17, 2004
    [​IMG]
    This would have been too high.
  7. annagibs
    annagibs New Member
    Sep 30, 2013
    Cleveland
    Yes way too high! Went back to the depot for a grinder and found the stainless flange with a smaller bevel. It still isn't completely flush with the tile it lips up maybe 1/8 on one side. Is that going to cause me any problems??
  8. jadnashua
    If the toilet fits over it without hitting (do a dry fit), and, you can anchor the ring to the subflooring (you might want to put a washer or shim or something to keep from deforming the ring), it will work.
    FWIW, Sioux city makes some they claim will fit flush in that situation...I haven't seen one in person, but supposedly, it's got a nice clean 90-degree angle on the bottom. You do want one with a SS ring, not the painted steel, though (and Sioux City does make them, too).
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you really want it to lay flat, a diamond blade in a 4" angle grinder will allow one to grind around the pipe to fit as needed.
  10. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    You mean grind the tile or pipe? Wear a dust mask when grinding tile...
Similar Threads: screwed tiled
Plumbing Forum, Professional & DIY Advice Can't get faucet cartridge unscrewed Sep 3, 2015
Plumbing Forum, Professional & DIY Advice Countertop guys screwed up sink install! May 16, 2015
Plumbing Forum, Professional & DIY Advice Help! I screwed up. Deep sink with disposer Dec 6, 2012
Plumbing Forum, Professional & DIY Advice I can't get this p-trap unscrewed. Oct 23, 2012
Plumbing Forum, Professional & DIY Advice new toilet install on concrete. Must be screwed down or not? May 29, 2012
