I need info on installing a booster pump and pressure switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by fcbclan, Mar 28, 2012.
  1. fcbclan
    fcbclan New Member
    Mar 2, 2012
    Forest City, Iowa
    I have a red lion pump with pressure switch mounted on it. What should my original pressure switch be set at, and what should the booster pump pressure be set at. Do I need any additional devices? I have a second pressure tank to add as well. Are CSV's required or can I get by without them until I can afford them?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The only adjustment you have is the pressure switch. Usually 30/50 with a jet, but you might be able to get 40/60 depending on which model pump you have. You can’t set the booster pump to a pressure. Without a CSV, the pressure from the booster pump will be determined by how much water you are using. No you don’t have to have a CSV. Your pump will just cycle on and off anytime you are not using the maximum flow the pump can produce. But a CSV and a 4 gallon tank would have saved you a lot of money compared to a large pressure tank or two, and the CSV would do a better job than both of those tanks together, and made your pump last longer.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    Seems like you will need a pressure tank if you dont do a csv. I found online - its a rebranded us made Amtrol 20 gallon tank delivered for 112$. Home depot has some for $120.... be careful some are NOT a good tank and have about the same look, seem to be chinese junk. the home depot website gives a lot of info on drawdown and place of MFG.
    At 112$, 2] 20's are quite cheaper than one of the 42 gallon rigs.
    If you have a multi stage booster, you could run it 45-75 psi and likely it will keep running as a csv will do when you have heavy use. 5 year replacement warranty on the tank.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    My guess is that the OP doesn't have a purpose built booster pump but rather a simple shallow well jet pump that he intends to use as a booster. As such the "booster pump" would not have a flow senser to control it.
    Using a regular jet pump cascaded to another pump has the potential for a vacuum to be applied to components not designed to deal with a vacuum.
  6. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Link please? That's cheaper than what I'm paying for wholesale for the "Pro Access" series.
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    Yeah Amtrol is really protecting their dealers. Just like Goulds, Franklin, Pentair and everybody else. :(
    That is just a regular WX202. They will tell you it has recycled rubber and a rubber schrader valve, where the "professional" series has virgin rubber and a steel schrader. I guess they have to try and justify it somehow. Still a WX202.
  8. ballvalve
    Dec 28, 2009
    Okay, now I let the cat out of the bag! You guys are gonna buy up all my cheap tanks!. Its a damn cutthroat world out there in this depression.
  9. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    How do you know it's really amtrol?
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    It says made by Amtrol, right under Well Worker,
  11. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    With all the Chinese counterfeits out there, one can never be sure.
  12. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    The amtrols I buy have 7-year warranties. I didn't see what warranty this one had.
    It might be made by Amtrol, but I have my doubts as to the quality. There are several "entry level" products out there made by the big companies like Franklin.
    The Franklin motor you buy at the Big Boxes is not the same as the one I buy. It has plastic heads and other shortcuts.
  13. ballvalve
    Dec 28, 2009
    Go to home depot website and says 'quality made in USA" 5 year warranty. click on specs and description
  14. ballvalve
    Dec 28, 2009
    Just got one and actually it has a SS Schrader valve with the usual double lock valve cap. But it does NOT say amtrol on the tank, but it clearly is one. great buy. No such thing as recycled rubber diaphragms except for door mats.
    I would say that the only difference is the 5 year warranty. Enuf for me..... not much more money than the worthless 4 gallon water heater ex. tanks!
    The box is made in Ohio, and its clearly a nice product. 1" SS waterway.
Similar Threads: need info
Pumps and Tanks Well Forum & Blog. Water is life. No water, need information and advice Jan 7, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Need Packer Jet well info. Aug 23, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Need information on an old Berkely submersible pump.... Jun 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Info needed on Sand Trap Manufactures/Distributors Dec 13, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Need some help with well information Oct 22, 2010
