I need help identifying a Roman tub fixture
kwhome
Wisconsin
Hello,
I've recently purchased a new home that has a Roman faucet on the tub that I need help identifying. Unfortunately the aerator is missing so I'm trying to locate a replacement. I've taken the fixture off and there are no labels or identifying markings anywhere to be found. I even tried taking it to a local plumbing store to have it identified and still no luck. The main problem is when faucet is used without the aerator, enough water sticks to the underside of the faucet, pools on the tub ledge and then streams to the floor. The thread diameter is about an inch. If someone can help identify this, allowing me to solve my problem, I would be grateful.
20160916_140130.jpg 20160916_131022.jpg View attachment 38525
Smooky
North Carolina
You might be able to identify the brand by taking one of the stems out. Either the hot or cold will do.
Most of the guides I have want to know the total length of the stem or cartridge, shape of the stem and spline count on the end of the broach.
Lay the stem or cartridge next to a ruler and take an in focus picture showing the stem and the length.
To determine the spline count you count either the grooves or the ridges on the end of the stem where the handle attaches.
An in focus picture of the handle end of the stem is helpful in determining the shape of the stem.
Pfister faucet. Call 1-800-PFAUCET for a replacement, because I doubt that anyone will have one in stock. I do not have the model number, but it may have been called a "Swan shaped" spout.
kwhome
Wisconsin
Hi Smooky,
Thank you so much for your input. I've added the requested images to the original post. I hope the new images are helpful. If there is anything else you need to see, let me know.
kwhome
Wisconsin
Hi HJ,
Thanks, I called Pfister and sent the images above to see if they could identify it as one of theirs. Still waiting for a reply.
