I need a 1 1/4" slip joint 90 degree elbow.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by enviroko, Jun 24, 2007.
  1. enviroko
    enviroko New Member
    Apr 2, 2007
    Anyone know where I can find one? They are tough to find on the web and Home Depot didn't have them. Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I assumed you are looking for PVC, but regardless of whether it's copper or PVC, go a a real plumbing shop. Box stores typically only handle items that have a fairly rapid turn over. Most plumbing supply houses say the will only sell to licensed plumbers, but for one or two pieces they usually will make a cash sale to anyone. Just don't expect to buy major items.
  4. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    sounds like he's looking for a slip joint 90.The one used for tubular brass.
  5. enviroko
    enviroko New Member
    Apr 2, 2007
  6. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    They are offering an 1-1/2" tee with 1-1/2x1-1/4 bushing washers.
  8. hj
    elbow
    A double slip joint elbow is a difficult fitting to keep together. What you need is a 1 1/4" "flush elbow" which has a slip joint on one end and a length of tubing on the other that you cut to fit as necessary. Good plumbing stores have them.
  9. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I assume this is for a bath faucet. Many times it's easiest to go from 1 1/4" to 1 1/2" at the pop-up drain using a reducing ferrule. Then use a 1 1/2" p-trap, etc..
Similar Threads: need slip
Plumbing Forum, Professional & DIY Advice Need help - p trap broke off, leaving a piece under the slip nut Jan 29, 2015
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Need 10" skirted toilet in ADA Feb 8, 2017
