I have a new softner but???
Discussion in 'Water Softener Forum, Questions and Answers' started by MOVIE GUY, Jan 28, 2010.
  1. MOVIE GUY
    MOVIE GUY New Member
    Jan 11, 2010
    WICHITA
    New softner, with clack 1.25, 10x54 tank, sst-60 resin, but my city water was 8 hardness before softener and now is 1 hardness? Should it not be o hardness?
    Thanks for any and all help.................
  2. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    Generally you should expect to remove almost all hardness--but even using SSt-60 resin there may be very small amounts of hardness leakage--perhaps 1-2 ppm or 0.1 gpg.
    What are you using to measure the hardness?
    What is your maximum flow rate through the softener? Hardness leakange increases with flow rate.
    How do you have the control set up? How often do you regenerate and with what amount of salt? What is your typical daily use of water?
  4. Gary Slusser
    Retired
    It sounds as if the softener may not be sized correctly and your peak demand flow rate is higher than the constant SFR of the volume of resin. And from your other post about the softener, you probably don't have it programmed right.
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Check to make sure that there are no open or partly open valves that would let untreated water cross into the treated side.
    When you did the test the water had been running for how long?
Similar Threads: softner
Water Softener Forum, Questions and Answers Softner runs continuously Nov 1, 2016
Water Softener Forum, Questions and Answers Time for new softner Oct 24, 2016
Water Softener Forum, Questions and Answers Very high TDS post-softner? Aug 18, 2016
Water Softener Forum, Questions and Answers Do Sulfates Affect Water Softner? Apr 28, 2016
Water Softener Forum, Questions and Answers Need help With Softner/Iron System Mar 11, 2016
