I have a leak
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Brewer, Mar 20, 2013.
  1. Brewer
    Brewer New Member
    Mar 19, 2013
    SC
    I recently purchased a house and my yard sprinklers and pool are supplied by well water. I noticed today that a faucet water line by the pool is leaking under ground and flooding my yard. I have a captive air tank well system (only one line going in/out), how do I turn the water off so I can repair the broken line. I switched off the Well circuit breaker tonight and opened up the faucet. I let the water run for appox 20 minutes, but the water kept flowing strong. How long should it take for the water to stop? Will the air deplete in the tank with the well turned off and water depleted from the tank? Will I have to add pressure to the tank before I switch the well pump back on?
    Sorry for so many questions, just moved in approx 3 months ago, and this is my first experience with a well. If I can get the water shut off repairing the broken water line wont be a problem. I just need to know if I should call a plumber to take care of the well. Any advice will be appreciated. Thanks!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    There should be a valve at the pressure tank.
    John
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you don't have a valve after the pressure tank to shut off the water to the line, just turn off the pump and drain the tank. If you have a big tank, like 80 gallon size, it holds about 25 gallons of water. With a small faucet, putting out 2 or 3 GPM, it might take 7 to 12 minutes to drain the tank. With the pump shut off, the water will stop when the tank is empty.
Similar Threads: leak
Pumps and Tanks Well Forum & Blog. Water is life. Young well leaking Jan 31, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Fixing minor leaks around pressure tank connections? Jan 23, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Winter well leak Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 leaking Nov 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well, Leak at Pitless Adapter Oct 5, 2016
