I have a dinosaur furnace/boiler in my basement...
Discussion in 'HVAC Heating & Cooling' started by Mad Plumber, Oct 23, 2008.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    there is a dial that starts at 60 and goes to 220...what does it mean and where do I set it too??
    It is metal and I can slide it back and forth to any number...I am in Boston and it is getting cold...Please help!
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    So what is it, a furnace (hot air) or a boiler (hot water or steam)? If it is a boiler does it supply hot water or steam? Do you have cast iron radiators in your house or baseboard heaters? What is the name/manufacturer of the equipment and what is the model number?
    But most of all, can you post some pictures of the equipment?
    To post pictures you need to first upload the pictures to a photo hosting site such as photobucket.com or villagephotos.com. and then post the public URLs for the pictures (or album) here. More pictures are always better than fewer. Please have CLEAR pictures and have both close up pictures and ones from a far enough distance that we can see how the various parts are interconnected.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The best thing to do here is call a service technician in before something dangerous happens.
  5. tedfrk
    tedfrk New Member
    Oct 21, 2008
    New Jersey
    pics would be great.maybe manufacturer and model.
  6. jadnashua
    To be certain what the adjustments are for, you'd need the manual. Often, they're the high/low set points for the boiler water. One sets the max where it shuts off, the other represents (when the system is calling for heat) it will allow it to cool off to before it turns back on. Basically, it defines the zone the boiler tries to maintain when heat is called for. Often, this is set with a difference of around 20-degrees F. To be certain, though, you'd need to see the manual. Your specific needs and the proper setting can't be done from here without knowing the whole system's requirements.
Similar Threads: dinosaur furnace/boiler
HVAC Heating & Cooling Furnace/boiler (and HWH) PLACEMENT Apr 3, 2010
