I hate cold showers!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by schistkicker, Sep 5, 2006.
  1. schistkicker
    schistkicker New Member
    Sep 5, 2006
    My electric water heater is about 7 years old, and I live in an area
    with hard water. Recently I returned from a 6 week business trip to
    find that there had been a power outage/surge at my house. Along with
    having to reset all my clocks, my water heater wasn't working either
    (although none of the breakers had been tripped). We reset it by
    pushing the shiny red button and all was well for about a day. We heard
    the heater start up and showers were hot again.
    The next day, the shower water was cold again. However, I cannot reset
    the heater again because the reset button isn't depressible - it seems
    like it's pushed all the way in and no matter how hard I try, it doesn't
    move. None of my breakers are tripped.
    Should I flip the breaker off then back on again and see if that works,
    or is it possible this is simply a heating element problem and I should
    call a plumber?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Sounds like a defective thermostat if resetting the breaker has if any results.
    If it is determined that the thermostat is defective.....replace both. They are inexpensive and eliminates the possibility of the other one failing soon after.
  4. hj
    cold water
    You could have a broken wire, a bad thermostat, a bad breaker, and in addition one or both elements could have burned out. Call a plumber if you do not have the equipment and experience to test the water heater. Do not spend money replacing things until you know exactly what has to be replaced, if you try to do it yourself.
Similar Threads: hate cold
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice I hate my neighbors Plumber Mar 26, 2013
Plumbing Forum, Professional & DIY Advice I hate shower diverter "valves" May 21, 2010
Plumbing Forum, Professional & DIY Advice Sharkbite Questions Code Leaks hate em like em Dec 24, 2009
Plumbing Forum, Professional & DIY Advice Don'tcha hate when... Jun 26, 2007
