I get a continuous flow of water from the backwash drain pipe (Culligan Medallist)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by toddomel, Oct 12, 2010.
  1. toddomel
    toddomel New Member
    Oct 12, 2010
    Murrieta CA
    My Culligan water softener all of a sudden has continuous flow of water going through the drain pipe. Not sure what is causing this problem. I noticed this once my water bill doubled from the month previous...any ideas?
  2. jadnashua
    You may get more 'hits' if you post in the softener section. It sounds like the control valve is stuck. Could be the motor has died, a gear broke, or something similar. Now, why that happened may be because the valve is stuck, which jammed things up. Have you tried to force a regen and watched to see if things work?
    You probably want to put this in bypass until you resolve it, or your water bill might be even more nasty next time.
Similar Threads: continuous flow
Plumbing Forum, Professional & DIY Advice Continuous Flow Trap Primer Mar 30, 2016
Plumbing Forum, Professional & DIY Advice Water Heater Pulling 18 Amps Continuously - Not Heating Apr 16, 2014
Plumbing Forum, Professional & DIY Advice Injector Pump Running Continuously (not switching off) Jun 16, 2011
Plumbing Forum, Professional & DIY Advice Kinetico Model 30 Continuous Discharge May 12, 2007
Plumbing Forum, Professional & DIY Advice we hear continuous dripping noise Jan 16, 2006
