I Found This Strange; screw found in supply tube.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dlarrivee, Feb 20, 2011.
  1. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I found this screw in a 3/8" copper riser under a bathroom sink... Obviously the faucet flows better now.
    You would expect it to be the screw that holds the washer onto the bottom of the stem, so I checked that, and there is a brand new screw and washer on the bottom of the stem.
    I guess the screw dropped and someone came along to fix a dripping faucet but never thought to go looking for that missing screw...
  2. jimbo
    jimbo Plumber
    Thank you very much for the photo. This is one of those things that "happens all the time" but I often get the feeling that when the many pros on here opine that a poster should check for such a thing, there is an element of doubt for the poster. His eyes are rolling back, and he says " that's pretty far out. Must be something else!"
    Now we have proof in living color that it is NOT far out!
  4. dlarrivee
    Jun 28, 2009
    Canada
    Just because, I checked the cold valve too, and the washer retainer screw had backed out almost enough for it to drop too...
  5. ballvalve
    Dec 28, 2009
    northfork, california
    Sounds like good water conservation devices. Leave them in.
  6. ilya
    ilya In the Trades
    Dec 10, 2009
    home repair -I am not licensed and never represent
    Akron Ohio
    Drop of locktite...
Similar Threads: Found Strange
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Foundation Drain to Sump - Code Rqmts? Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Wet spot of home foundation, possibly plumbing leak in pipe going through foundation? Jun 25, 2016
Plumbing Forum, Professional & DIY Advice What do I need to replace corroded cast iron drainage pipes underneath slab foundation? Jan 18, 2016
