I Discovered A Great Way To Go Through Concrete Walls (Air Chisel)
Discussion in 'Remodel Forum & Blog' started by driz, Nov 26, 2009.
  1. driz
    driz New Member
    Sep 8, 2008
    I needed to make a 6" hole through a poured concrete foundation in my basement. I got a nice new makita hammer drill masonary bit for my drill and found out how ugly it could be. Forget that. A real masonary drill costs too much and I didn't want to rent one so I thought what about my hand held air chisel. It is a cheap HF job I used a few times for cutting panels or drum tops off . Thats about all I thought it was good for. Then I tried it on the 15 year old cement. Wow does it cut. Of course it is still a 6 pack job and one hell of a mess but its a lot easier to use than a drill. Strangely it doesn't even dull the Chinese cheapo tips at all. What's best is that there is no need to lean hard on the gun and it doesn't take a monster air compressor either. Just put a little pressure on it and let the spring do the work. I bet I paid a whole $15 for the thing. Incredible. The only thing I wish I had was a longer set of Ajax chisels.
  2. Terry
    Aug 17, 2004
    Or you can get a core driller out there.
    They use diamond tipped drills, and they do a clean core without any dust.
    They keep the dust down with water, which also cools the bit.
    It will slice right through rebar.
  4. driz
    driz New Member
    Sep 8, 2008
    Ah Yes But The Price $$$$$$
    Ah yes very true Terry, but as always its that on little thing, $$$$$$$$:mad::mad:. For you pros it is a gotta have item but for us once every 5 year slobs, well ya know.........
  5. hj
    chisel
    The problem with ANY chisel, and I have used my air chisel a couple of times but it is usually too "light" for major drilling, is that the deeper you go the narrower the hole gets.
  6. export!
    export! DIY Member
    Oct 19, 2009
    Ontario, Canada
    Ahh.... so true with so many things in life.
  7. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I used a combination of a sledgehammer, cement drill bits/hammer drill & air chisel to get a 3-4" hole thru for drainage
    It was from a crawl space under my sunroom out to my drainage pipe
  8. Terry
    Aug 17, 2004
    When I was doing new construction in my 20's, and I needed a hole big enough for a 3" waste line through the 8" foundations, I would only use a sledgehammer.
    Five blows with a sledge before the back side would pop out.
    And then a few more to make it large enough for the pipe.
    These were fairly green walls.
    If the walls have cured, then I like coring them.
Similar Threads: Discovered Great
Remodel Forum & Blog Basement remodel begins this week, any feedback will be greatly appreciated Nov 22, 2011
