I can't get this p-trap unscrewed.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lukers, Oct 23, 2012.
  1. lukers
    lukers New Member
    Oct 23, 2012
    Minneapolis, MN
    Any suggestions for removing this drain?
  2. kevink1955
    kevink1955 Member
    Nov 17, 2011
    L.I. New York
    I am not about to be the one to open a link from a poster that has 1 post and just joined.
  4. lukers
    lukers New Member
    Oct 23, 2012
    Minneapolis, MN
    I am sorry sire, these are troubling times in the kingdom and your year spent tirelessly honing your craft on a forum shouldn't be wasted on a newbie. I am sorry to waste your time.
  5. Terry
    Aug 17, 2004
    It looks like you have already removed the slip joint nut, leaving only the brass ferrule behind. If you are removing the p-trap, then it's at the point where you can just pull it out now.
    Coming from the santee, you have a short galvanized nipple, then a brass trap adapter that should have had a brass ferrule and a slip joint nut. You may need to muscle it out of there.
  6. hj
    You may NOT be able to just pull it out. There is a lot of corrosion on the tubing inside the pipe. You can try twisting and pulling it so you scrape the stuff off, or cut the tubing at the face of the brass fitting and cut the brass tubing out with a hammer and screwdriver, or just unscrew the brass trap adapter and then remove the tubing or install a new adapter.
Similar Threads: can't p-trap
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Can't find this sink clip Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out knocking pipes... Oct 31, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out what this sound is. Help? Aug 26, 2016
