Hydronic water systems problems
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dwivey, Nov 14, 2004.
  1. dwivey
    dwivey New Member
    Oct 23, 2004
    I have a very weird problem in my forced hot water system with a propane furnace. One of the zones (of 6 including a boilermate water heater) makes a lot of noise like water hammer and clammering and vibration. This occurs very sporadically. But when this zone is calling for heat and the furnace is cycling. I get this tremendous noise. It only occurs when this zone is calling for heat and only occurs when the furnace is firing. I have bled the system a couple of times now by closing all valves in the system, opening the boiler feed, zone return and supply valves and running a hose off at the end of the zone water circuitin this particular zone. I still get what I think is air in the system. Can someone explain to me how air can get into the system? Could I have a faulty bleed valve? faulty expansion tank? What are the symptoms of such faulty devices? PLease help if you can...
Similar Threads: Hydronic water
Plumbing Forum, Professional & DIY Advice Converting Steam to Water hydronic heat - how to pipe radiator? Jul 9, 2015
Plumbing Forum, Professional & DIY Advice Combicor vs. Genesis vs "on demand" for small unit hydronic heating & H water Jan 15, 2010
Plumbing Forum, Professional & DIY Advice hydronic water system problems part 2 Nov 21, 2004
Plumbing Forum, Professional & DIY Advice Hydronic heat system freeze damage Nov 24, 2016
Plumbing Forum, Professional & DIY Advice Help sizing pex-al-pex for hydronic heating Oct 5, 2016
