Hydronic system in -25 Celsius (-14 Fahrenheit)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BRCollette, Feb 21, 2011.
  1. BRCollette
    BRCollette New Member
    Feb 20, 2011
    Accountant
    Calgary, Alberta
    Hi everyone thanks for such great forum. Hoping someone can give me a hand here. I live in a small 10 unit apartment building originally built in the 1960’s. There is a hydronic heating system that works really well *except* when it matters the most! What happens is that when it gets *really* cold outside, meaning when the temperature falls below -25 Celsius (so -13 Fahrenheit), I always wake up in the morning and my apartment is absolutely freezing. Something happens in the night, only when it is super super cold that somehow “knocks out†the system. I know that it is only my unit because my buddy lives downstairs in another unit and his heating is fine. The other odd part is that when I turn the thermostat up when this happens….nothing happens.
    How the problem gets resolved is that I leave for work with the thermostat turned way up and when I get home 10 hours later it is always back on.
    I don’t understand what happens to make the system “re-start†– BUT I can confirm that before I leave in the morning I go put my hand on the Honeywell valve that is there at what I assume is the main water entry point to my unit from the boiler and it is freezing cold. There is no water there at all. This thing of course is always super hot. I don’t understand the specifics of how the water reaches my unit from the boiler, so I can’t quite understand what is wrong or even what causes the system to “re-startâ€
    The other day this happened on a Saturday for the first time so I was home and could observe when the system re-starts. I was freezing, but it took about 5 hours from when I woke up freezing cold to when water reached the main valve in my unit, it then took several hours for the apartment to warm. I am very confused about what is going on in the system during those five hours when the thermostat is turned up but no water appears to be at the valve.
    The final bit of information that might be useful for anyone that might be able to help me understand what is wrong is that my unit gets very warm and I usually turn down the system at night. I think this might have something to do with it. I am wondering if this can “knock-out†the system? I usually turn it down to 15 degrees Celsius (59 F) and go to sleep. It’s almost like reducing the setting to this temperature somehow causes the system to stop, and that when its super cold, something else happens to completely shut the system down.
    Can anyone give me a hand here understanding or have a solution? Of course the worst part about this is that it only does this when it’s *super* cold. I have come to expect that my heating will fail for a day when we are in a cold spell.
  2. jastori
    jastori Member
    May 2, 2008
    Illinois
    Is it possible that a pipe is freezing? This is one situation when the problem could occur overnight, and then "fix itself" later in the day.
    I assume the 10 units are sharing a single central boiler? The control valve for your unit should then be opening and closing periodically to let hot water run to your unit. When you turn down the heat for the night, there could be a period of a couple of hours in which your unit is not calling for heat, and therefore the valve remains closed and water stops flowing in your unit. This could be enough time for a pipe to freeze.
    If this is happening, one "fix" would be to somehow improve the insulation between the pipes and the cold exterior walls. Other solutions could involve changing the control system so that water does not stop flowing for such a long time.
Similar Threads: Hydronic system
Plumbing Forum, Professional & DIY Advice Hydronic heat system freeze damage Nov 24, 2016
Plumbing Forum, Professional & DIY Advice Setting up hydronic system with a backup Feb 7, 2015
Plumbing Forum, Professional & DIY Advice Boiler system for hydronic heat - where to put check valves? May 5, 2014
Plumbing Forum, Professional & DIY Advice heat rising to second floor in 2 zone hydronic system Apr 6, 2006
Plumbing Forum, Professional & DIY Advice iron to copper on hydronic system Mar 25, 2006
