Hydronic BAseboard Sizing
Discussion in 'Boiler Forum' started by R3Improvements, Nov 16, 2009.
  1. R3Improvements
    R3Improvements DIY Junior Member
    Sep 20, 2009
    Toledo, Ohio
    Is there a formula I should follow when sizing a new hydronic baseboard heater? I'm remodeling a bathroom in a 100 year old house.
    Thanks.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    You need a Manual-J or IBR type calculation of the heat loss to know how many BTUs you need to pump in there.
    Then you need to know your water temp from the boiler.
    You need to know the approximate flow rate in that loop.
    You need to know where in the loop (unless it's a micro-zone with it's own thermostat), and calculate what the water temp coming into that baseboard is based on flow & amount of radiation that precedes it.
    Then you can look at the manufacturers' spec on how many BTUs/ft you can expect to get out of their baseboard at that temp.
    Without the heat loss, water temp, flow & other radiation you're just hackin', stabbin' in the dark.
    This guy has something of a hydronics primer online, if you want to take the time to actually design it rather than hack away at it: http://www.heatpro.us/
Similar Threads: Hydronic BAseboard
Boiler Forum No Space available!!! Could I install hydronic baseboard vertically? Oct 26, 2015
Boiler Forum Newbie boiler / hydronic baseboard sketch & basic troubleshooting Sep 22, 2013
Boiler Forum Questions about hydronic baseboard heat Sep 9, 2013
Boiler Forum Incredible Introduction to Hydronic Systems Sep 18, 2016
Boiler Forum 100% hydronic heating guy Mar 6, 2016
