Hydro Air Coil Pex sizing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by santanaf, Oct 30, 2006.
  1. santanaf
    santanaf New Member
    Oct 8, 2006
    I am installing a hydro air coil in my attic and am running Pex up. The coil has 3/4 stubs for in/out. I have 1/2" pex I will be using for my radiant flooring application, and a Taco 007 IFC circulator. Will this be sufficient for my 36,000 BTU needed or should I run a larger diameter PEX. Boiler is 50' run from the air handler's hydro coil. I am insulating the PEX very well, esp in the attic.
Similar Threads: Hydro Coil
Plumbing Forum, Professional & DIY Advice Replacing a Hydromatic DA-1 10 with a Zoeller M98 or Liberty 287 Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Hydronic heat system freeze damage Nov 24, 2016
Plumbing Forum, Professional & DIY Advice Help sizing pex-al-pex for hydronic heating Oct 5, 2016
Plumbing Forum, Professional & DIY Advice PEX A, B, Or C, With Hydrogen Peroxide Injection? May 5, 2016
Plumbing Forum, Professional & DIY Advice Relocation Expansion Tank - Hydronic Heating May 4, 2016
