HVAC Wiring
Discussion in 'Electrical Forum discussion & Blog' started by charp, Oct 23, 2011.
  1. charp
    charp New Member
    Jul 18, 2011
    Grass Valley, California
    The HVAC unit (LP gas furnace) is made by Bryant around 1990 and was wired with a flat, black insulated wire with two 8 gauge conductors and a small ground. Shouldn't it be wired with 8/3 with ground? I have to remove some decking to access the disconnect box mounted on the wall by the unit to see what kind of wire runs between the unit and the disconnect box. Yes, some bright person actually built a deck right over the unit and covered the shutoff box! I should post a picture of the original Zinsco subpanel to really scare y'all.
  2. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    if you are talking about an a/c unit that is run off of 220v, all you need is two wire w/ground since the neutral is not used.
  4. charp
    charp New Member
    Jul 18, 2011
    It's an all in one unit, AC/gas furnace/fan, installed outside the house. I have some 8/3 that I can use to reach the new subpanel, I just won't use the neutral. Thanks
  5. jadnashua
    The installation manual would indicate if it needs a neutral (which would allow some internal 120vac circuits/devices), but it probably doesn't need it.
Similar Threads: HVAC Wiring
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Yesterday at 7:29 PM
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Yesterday at 7:05 PM
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Doorbell Wiring Dec 29, 2016
