Hunter SRR Remote Failure??
Discussion in 'Irrigation / Sprinkler Forum' started by gkrckid, Jun 3, 2007.
  1. gkrckid
    gkrckid New Member
    Jun 3, 2007
    I've got a Hunter Pro C controller with an SRR remote. It has worked flawlessly since install in '03. After using the remote a couple of times this spring, it quit working. TRied resetting the address - no help.When I plug in to reset, I do get the proper 4 beeps, but nothing after I hit a button on the transmitter. If I plug in the receiver without pressing the reset button, I get the normal 2 beeps. A couple of the resistors on the receiver get warm, is this normal?? Any source of parts or other defective units?? Any info on what the transmitted signal shoud be?
    Only other thing I noticed is that when the receiver is plugged in, one or 2 'r's will show on the display. Is this an error message???
    Many thanks in advance
Similar Threads: Hunter Remote
Irrigation / Sprinkler Forum Hunter Spray Head - More than 360? Jan 27, 2017
Irrigation / Sprinkler Forum Hunter Icc Controller Question Jul 26, 2014
Irrigation / Sprinkler Forum Hunter Pro-C System May 12, 2013
Irrigation / Sprinkler Forum Hunter System Winterizing. Need some help with hookup. Valves not coming up Dec 2, 2012
Irrigation / Sprinkler Forum Internittant Problem with Hunter controller Aug 16, 2012
