Hunter Sprinklers
Discussion in 'Irrigation / Sprinkler Forum' started by jerome8283, Apr 23, 2007.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    Can you spray the rotary (PGP) and spray (PS) heads with a little WD40 so they popup and go down without becoming stuck in either position?
  2. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    I think that the wd 40 might eat the plastic and do more harm than good. You might try to use a waterproof grease or a dry lube type spray.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think anything you put on would soon wash/wear off. Are you sure the heads aren't just a bit dirty for setting over the winter? Let them run and cycle through a few times and see if nature doesn't cure the problem.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    The first time you turn on the system in the Spring, it's a good idea to clean off all the grass and dirt that has accumulated around or in the sprinkler heads. Then manually lift up and down on them a few times to clear out any other obstruction. If they still don't want to pop up, you may have a water pressure problem.
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    If they don't pop up, then it would be a pressure problem. If they don't go down, then clean as suggested.
  7. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    The most common cause of head popup/popdown problems is their being installed too low. A case of Hunter PGPs has a drawing on the box showing the proper install height. And yes, the proper height will seem to be too high. In most cases, the growing lawn will continue to build up, and today's too-high head will be a too-low head in some future year.
Similar Threads: Hunter Sprinklers
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
Irrigation / Sprinkler Forum Hunter Spray Head - More than 360? Jan 27, 2017
Irrigation / Sprinkler Forum Hunter Icc Controller Question Jul 26, 2014
Irrigation / Sprinkler Forum Hunter Pro-C System May 12, 2013
Irrigation / Sprinkler Forum Hunter System Winterizing. Need some help with hookup. Valves not coming up Dec 2, 2012
