Hunter rotor head adjustment screw
vaman
NJ
I have a couple of hunter rotor heads that I cannot get the adjusting tool to catch the adjusting screw so I can change the spray distance. Any ideas on how else to turn it or what other options I have?
vaman
NJ
Distance adjuster screw
The distance adjuster uses either a small flat screwdriver or an Allen wrench. The special tool adjusts the rotation arc.
I've tried the special tool, an allen wrench and screwdriver. I don't know how but maybe the top got stripped.How I can I get that screw out or is there something else that will turn it?
tomm
At least half of the hunter heads(that I come across) allen head spray distance screws get plugged up with debris/dirt making them extremely difficult to adjust.
vaman
NJ
Thanks
If your screw has debris in it, try using a pin or needle to clean it out. It should NEVER have become so tight that you would have stripped it.
It worked! Thanks so much!:D
dargo
MA
What I do it try and clean them..If not, throw the complete head out since they are cheap...
