Humming noise in water pipes after installing an RO filter
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thogman, Feb 24, 2010.
  1. thogman
    thogman New Member
    Feb 24, 2010
    We installed an RO filter at our office. Instead of using the provided saddle valve, we installed a tee at the end of the cold water hose where it attached to the faucet and reduced one of the outlets to fit the 1/4" compression fitting. Whenever the RO filter is refilling the tank there is a loud humming noise coming from the water pipe. It is possible the humming will stop if I use a saddle valve instead of the reducer on the tee?
  2. jadnashua
    Saddle valves are a disaster waiting to happen. I'd avoid using one. Not sure what is causing the humming. It may be normal with that unit. What is your water pressure? It could be higher than recommended for the filter. Rather than that T, they do make dual outlet shutoff valves. It might be quite easy to replace the shutoff.
Similar Threads: Humming noise
Plumbing Forum, Professional & DIY Advice loud low humming noise associated with outside irrigation systems Sep 25, 2006
Plumbing Forum, Professional & DIY Advice Faucet makes odd humming noise Apr 4, 2006
Plumbing Forum, Professional & DIY Advice Humming noise in natural gas pipes in the house Dec 19, 2005
Plumbing Forum, Professional & DIY Advice Humming Noise Apr 7, 2005
Plumbing Forum, Professional & DIY Advice Loud humming noise in pipes Mar 25, 2005
