Hub vs spigot fitting advantages
Discussion in 'Toilet Forum discussions' started by Tmax, Apr 23, 2012.
  1. Tmax
    Tmax New Member
    Apr 23, 2012
    Ontario
    After a bathroom reno I am replacing the toilet flange to the 3" abs. Is there an advantage to using one type of fitting over the other of the flange? I see the spigot flange being more failsafe if the fitting wasn't properly bonded since it is sitting inside the pipe. However is the reduced inside diameter of the spigot fitting compared to a flange with a hub fitting more likely to plug? Thanks
  2. Terry
    Aug 17, 2004
    The spigot is the same as pipe size; therefore it isn't reduced.
    Whether you would use spigot or hub depends on the pipe or fittings.
    I tend to use hub flanges most of the time.
Similar Threads: spigot fitting
Toilet Forum discussions Toto Carolina Spigot to Rubber Sleeve connection. Jan 28, 2012
Toilet Forum discussions spigot-style flange that fits into 3" hub: waxless seal options or toilet options Feb 23, 2011
Toilet Forum discussions Where to get European style rear spigot toilet? Feb 18, 2011
Toilet Forum discussions Street 45/45 closet flange vs. spigot closet bend May 11, 2009
Toilet Forum discussions Help please...base not fitting problem Nov 12, 2015
