HPS light problem
Discussion in 'Electrical Forum discussion & Blog' started by rayh78, Sep 15, 2008.
  1. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Tried to install a 50 watt HPS light. Would keep turning on and off after couple of minutes. Tried another fixture and same problem. Finally got it to work right by not having the ground wire connected.
    Trying to figure out why this happened.
    Also had checked no bare wires in box that could be touching.
    Meter showed 119 volts between black and ground or black and white. Nothing between ground and white.
    thanks
  2. hj
    power
    What about between the fixture's green wire and ground when the light is turned on?
  4. jimbo
    jimbo Plumber
    Is this fixture being controlled by a motion sensor, or photocell?
Similar Threads: light problem
Electrical Forum discussion & Blog Light Fixture or switch problem? Nov 6, 2015
Electrical Forum discussion & Blog BROAN Fan/Light Problem Feb 3, 2014
Electrical Forum discussion & Blog Low voltage light flicker problem Jun 13, 2009
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Vanity Lighting Issue Jan 7, 2017
