How to wire my gang box
Discussion in 'Electrical Forum discussion & Blog' started by woody9663, Feb 14, 2012.
  1. woody9663
    woody9663 New Member
    Feb 13, 2012
    ont canada
    Hi I am new here.I have a gang box which i changed from shallow to deep.I andded another wire for a light.A friend did a drawing for me but it did not work.Can someone help me the wireing??
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    So are there three switches or just two?
    And if two what do you want switched together? There are three items switched.
  4. woody9663
    Feb 13, 2012
    ont canada
    Thanks 4 replying -There r 2 switches..left side laundry room light..right side mud room light that also switches on the btm of the plugs in that room..smoke alarm on at all times.. i hope that helps if not ask me more please cause i do need help
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    All the white wires will go under a wire nut.
    The black from the supplying circuit, the black from the smoke alarm and two pig tails that will land on each switch under a wire nut.
    The black wire from the mud room light and the black from the receptacle will go under a wire nut with a pig tail that will hit the other screw on one of the switches.
    The remaining black wire on the last switch.
    Not sure how the top half of the receptacle is being supplied as you don’t show that conductor if it is in the same cable as the switch leg going to the receptacle it will go under the same wire nut with the supply
  6. hj
    If that is his drawing, it is completely useless, but the actual wiring is so rudimentary, that if you cannot figure it out, maybe you should not be doing the job.
  7. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    Or at least go buy a book at the home center describing home electrical.
    And turn the dratted circuit off before doing any work!
  8. jadnashua
    A sketch of what you are trying to accomplish may make this easier to understand.
    To be protected and have a GFCI work, if you plan to use the 'Load' leads (i.e., feed anything else from that GFCI receptacle), the neutral for the load side can ONLY be connected to the items fed by the hot from the GFCI load side, and not to any other neutrals from any other circuit.
    A GFCI works by comparing the current between the load hot and neutral. Any current flowing from another circuit will unbalance that, and cause it to trip.
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The above poster claiming to be from "Belgium" is a spammer that posts things in forums only so that it can add a link to a a website in the post.
    The actual text in the post comes from other websites on the internet. It is part of an automated spamming operation.
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    This guy is ALL over.
  11. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Nice Catch...
Similar Threads: wire gang
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Can I wire in an oven to this sub panel? Feb 21, 2017
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog What Monkey Wired this outlet?? Jan 10, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
