I have a finished basement and bought a Floodstop water leak detector with an electrically controlled valve. For various reasons I would rather use this controller for interrupting the power to my well pump in case of a water leak in the house. When the flood stop controller is activated, it sends 6vdc to the electric valve. I have a Square D pressure switch and a Franklin 2823008110 pump controller. I guess I could just wire in a 6vdc relay into one of the legs going to or from the pressure switch to cut the power. If that is true, should I be concerned about the amperage running through the relay or any other potential problems? What do you think?
Thanks in advance!
Thanks in advance!
